Ultegra 10-speed
si_c
Wirral
Try loosening the cable at the derailleur and see if you can move it by hand.
Could also be grime or something in the cables causing too much friction.
iluvmybike
Gear cable has broken off inside shifter and jammed it - you will need to try and get in to find the head and remove the broken strands of metal :sad:
