Tyres
mrs fry
rsvdaz
Devon
these get good reviews:
http://www.halfords.com/webapp/wcs/...9_categoryId_228356_langId_-1?cm_vc=IOV4PLPZ1
Wiggle have a deal 2 tyres and inner tubes for £31.99..you should get them delivered next day even with the free delivery option
M
mrs fry
Jakes Dad said:
Mrs Fry ... how long have you had the bike ? and did a Halfords employee advise you that this was the best bike for your needs ?
Simon
I didn't ask them. I had no option but to simply go for the cheapest bike there was. And I was clueless enough not to know the different types of bikes for different terrains.
I bought it just over two weeks ago. The chain keeps coming off, the gears are dodgy and it rattles all the time. I've took it back once and he said the gears were slipping but that it's okay now.
It's just a terrible bike.
jig-sore
Formerly the anorak
Rugby
but you still keep going back to halfords !!!!!!
there must be a local bike shop that can help you out.
i wish you would have asked for advise before you got the bike. with that much money to spend we would have told you to look for a second hand bike "without" suspension. try your local tip (they call them recycling centres these days). you can pick up real bargains, i've done it.
please find a real bike shop that can help you out with your problems, i would not like my wife to be in the situation you keep finding yourself in. no one should be close to tears because of a bike (although i do swear at mine when it slips a gear)
jig-sore
Formerly the anorak
Rugby
you can get decent tyres for £10 at your local bike shop the same as you can get at halfords BUT on top of that you will also get good advise from someone who knows what they are talking about
you can also get decent tyres on-line with free postage for £10, try chain reaction cycles.
I'm wondering if you might have a case to return the bike as it is not fit for purpose ? and either buy something secondhand that is more suitable to your needs or if Halfords will do an exchange for another model you can get the Carrera Subway (female) for £183 with the extra 20% discount that they are giving on all Carrera bikes
I dont like to think that your throwing your money away on new tyres for this bike
Simon
M
mrs fry
Simon
Yeah, but it's probably just because I'm not very clued up on maintenance. I'm trying to think how I could get away with taking it back without them just exchanging it for the same one or fixing it.
It might be worth contacting Halfords customer services and explaining that the bike has been extremely unreliable and it is'nt fit for its intented purpose and ask about the possibility of exchanging the subway for something more suited to your needs ?
Give it another day to see if your thread in the cafe throws anything up ... can you take the bus for a few days rather than upsetting yourself with the bike ?
Simon
mcshroom
Bionic Subsonic
From the list I wouldn't think you'd go far wrong with the continental double fighters, but I wouldn't go chasing tyres just yet (although they do make a real difference they are not imperative). Getting the bike to work properly is far more important for both your confidence and how your commute feels.
As for the bike, it's your bike, it has two wheels, pedals saddle handlebars, brakes just the same as most other bikes. There should be no reason for the bike not to do you perfectly well enough for the commute you have, but it needs properly setting up and I would suggest that this is where Halfords have to deliver.
How long have you had the bike, as it appears from what you have said through your other threads that the bike has not been sold to you in a state that is fit for purpose and it is their responsibility to fix it or provide you with a replacement or refund.
I would suggest you go back to them and point out that the bike is not fit for purpose, and you demand that it be made so. They make a point about their setup of the bike: -
Don't forget all bikes purchased from Halfords include build, safety check and 6 week first service free of charge.
Make them work for it! :smile:
Oh and don't let this experience put you off cycling. Halfords are IMHO unfortunately both, through their big high st stores, one of the greatest enablers of cycling to people new to bikes, and due to their bad setup one of the reasons many people give up cycling. You don't need the shinyest carbon bike in the shop, if the bike works properly then it should be perfectly capable of getting you where you need to go (and it does get a bit easier as your body becomes more used to it). Just think about how enjoyable riding the bike in the summer sunshine will be.
Every time you get annoyed with your bike as it grates away, just think how much money you would have had to spend to get the same workout in a gym :becool:
Sheffield_Tiger
Simon
Might be a long frustrating battle to return the bike as NFFP although it's absolutely disgusting the way Halfrauds let unsafe and dangerous bikes out on the road (my Virtuoso was given to me in a poor state with ALL the limit stops out - chain came off in the car park! - the front mech wrongly positioned and the rack I bought at the same time left with loose mounting bolts.)
Just a thought re: unsuitable bikes and the rear suspension, anyone ever locked out the rear suspension with a cut to length piece of tube in place of the spring? Should be theoretically possible, would take away some of that energy sapping bouncing around. At the very least, I would ensure that the adjuster on the spring is screwed as tight as you can get it, to preload the suspension and make it less bouncy. This should reduce the amount of pedalling energy you use bouncing yourself up and down instead of propelling yourself along,
An MTB is fine for commuting, done plenty of miles on a heavy old mustang in the past, but it does need to be a hardtail really. Though sometimes I'll be thinking I'm making good time and someone will breeze past on a bouncy BS without breaking a sweat - which is always annoying
Re: tyres, perhaps something not too pricey?
http://www.sjscycles.co.uk/product.asp?pf_id=18722&src=froogle
Should be fine for normal commuting use for the time being. I don't think anything fancier is going to make a world of difference at the moment.
M
mrs fry
Simon
Work is in the middle of nowhere, no public transport.
