Tyres
nickg
Right ive had a puncture in my front tyre. Ive felt inside the tyre and unable to feel anything. Put the tube in water and unable to find a leak. So it went down again so I changed the tube to a new one. And over 5 days has gone flat again. Am I able to turn the tyre inside out to check visually aswell as feel for debris? Its puzzling me and I dont think its my daughters, wife or dog.
Booyaa
Leaky valve?
Overconfidentii Vulgaris
My guess would be that there is a thorn in the tyre but it's not pushed through far enough to find easily. If you wipe round the inside of the tyre with a bit of cotton wool it'll leave strands snagged on anything that has penetrated.
Other possibilities are loose valve cores or the valve not sealing properly due to getting dirt into it.
andrew_s
Gloucester
Use the punctured tube to find where the sharp in the tyre is. It's much easier to find the problem of you are only looking at a small section of tyre rather than the whole thing.
a) when removing the tube, take care not to turn it round with respect to the wheel/tyre
b) pump up the tyre until you can find where the air is coming out. If you can't find it, pump up some more. Tubes will expand up to 6 feet in diameter, by which time even small holes are stretched enough to be findable.
c) mark the hole in the tube - tippex/ballpoint/whatever
d) let the tube down until it's the same size as the tyre
e) line up the valve with the valve hole and closely inspect the tyre where the tube marker is
Feel free to turn the tyre inside out, or to poke down small cuts feeling for any small fragment of glass that may be lurking within the thickness of the tread.
Probably the hardest to find is a short length (1-2mm) of wire strand. It may not be long enough to be apparent on the inside, and there may only be a small pinprick visible outside.
youngoldbloke
^ this. Also makes it easier if when you fit a tyre you line up the logo on the tyre with the valve. I carry a pair of fine point tweezers to remove tiny thorns, flints etc.
