Tyre Size
Sterba
London W3
yes, no probs
GrasB
Nr Cambridge
Will a 700x23c tyre fit on a 700x28c rim with no problems??
Depends on the inner width of the rim. As a general rule you'll have all kinds of problems with the tyre pulling away from the side of the rim if you try to put a tyre on a rim which is narrower than the the outer width of a rim at the braking surface.
