Any difference will be marginal. The current trend is to do the opposite, even going up too 28mm if there is enough clearance, since the thinking is that you can run the wider tyre at a lower pressure for more comfort at no cost to rolling resistance or roadholding. There should be more grip with more rubber on the road.
