Good morning.
I have a question regarding tyre replace on my bike.
It currently has a rear wheel puncture. The tyre is a tubeless one. They are maxxis overdrive excel 700x35mms. I have looked at a replacement tyre but none are in stock at 35mm width, but I can get 32mm. I have tried for the 35s with no avail. So, my questionis is;
Is the 700x32mm tyre width compatible with the set up with it being 3mm less in width (same diamater)?
I'm hoping the slight drop in width wouldn't pose much if any a problem. But I'm new to cycling so please bear with me if this is a stupid question.
Any help will be much appreciated!
Thank you
Thank you
