I changed inner tubes last night for 700c 28 tyres with 27 1 1/4 tube, which I believe are basically the same with different metric and imperial measurements. However after swapping I have noticed that the tyre isn't catching the outter rim. Is this just because there needs to be more inflation? I was using a hand pump and stopped when I felt the tyre was relatively full and there started to be more resistance when pumping. Is it easy to burst inner tubes from too much pumping? I tried to ride it once and the tyre went flat almost immediately and lost a lot of pressure.
