Two bikes into one. Impossible question?
cameramanjim
Getting faster, very slowly
For some reason I´m under pressure at home to reduce my four bikes to three. Can´t think why!
Winter & summer road bikes are staying though.
I commute on a single speed and have a Trek hybrid for shopping and rides in park with kids.
I´d like to replace these two bikes with one that would do both jobs but not sure if such a bike exists? I don´t want a standard geared bike for the commute (maintenance, no hills) but I need some sort of gearing for the shopping because there are some short hills near me that I need to climb with full paniers.
So I´m thinking about hub gears.
I´ve heard the gears are fairly low range (29-91 inches) which sounds ideal?
I´m also trying to avoid a heavyweight bike because of the commute.
Mudguards and a rack on the bike are a must.
The only ready made bike that I can find that is anything like what I´m looking for is this Geneses Day One Alfine:
http://www.evanscycles.com/products/genesis/day-01-alfine-2011-hybrid-bike-ec024744
On the down side it´s heavy-ish (but would be lighter with different tyres) and my LBS say the disc brakes are not maintenance friendly. I like orange so that´s not a problem!
Does anyone know of any similar bikes or should I be thinking of a custom build?
corshamjim
Corsham
If you're after a drop-barred hub-geared bike, then your choice off-the-shelf is going to be somewhat limited.
The only other ones which come to mind are the On-One Pompetamine Versa http://www.on-one.co.uk/i/q/CBOOPOMPETVERSA/on-one-pompetamine-versa and the Pashley Clubman Urban http://www.pashley.co.uk/products/clubman-urban.html
You might find it better and cheaper simply to replace the rear wheel on your single-speed with a hub-geared one. SJSC have a good selection of hubs available and can build the wheel around it for you. Personally I use a Sturmey-Archer 3-speed with 90mm drum brake (XL-RD3) which is one of the heavier options, but having a drum brake means there's no rim wear and almost no maintenance.
cameramanjim
cameramanjim
Thanks for your reply. Doesn´t have to be drop-barred. My SS isn´t set up for paniers etc but would have been a neat solution. I´m trying to find out if Genesis sell the Day One frame separately.
Like both the bikes you linked to.
Plenty to think about.
Thanks again!
Jim
The only other ones which come to mind are the On-One Pompetamine Versa http://www.on-one.co...mpetamine-versa and the Pashley Clubman Urban http://www.pashley.c...bman-urban.html
