turbo trainers
i am thinking of getting a turbo trainer but have questions.
are they worth the money.
how does the bike connect to it. do you remove the QR pin and put it in the turbo trainer or do you use a different wheel.
i have heard they are noisey are they.
are they worth the money. IMO no, but that's because I don't like using them.
how does the bike connect to it. Just drop your wheel in the space and tighten. No need for different wheels or tyres IME.
i have heard they are noisey are they. Some are, some aren't. Depends on price, spec and floor surface.
My advice FWIW, buy a used one. There are loads about because lots of people, (like me), get one, try it and simply hate it.
If you like it you should get your money back if you've bought second hand then choose to upgrade it.
If you buy new and don't like the experience then you'll take a pounding when you flog it.
It's possible to make significant fitness gains by using a turbo correctly. So, if improvement is your aim, then yes. Not all turbos are the same price, so value is a difficult question to answer.
Most turbos are supplied with their own QRs, for use specifically with the turbo.
Some are, some aren't. Fan-resistance units can be noisy, while magnetic and fluid units are much quieter.
Rob3rt
Man or Moose!
Manchester
If you use it, yes, if you look at it, no
It depends on the turbo trainer, most commonly they clamp over the QR skewer caps (you often get a QR skewer with them to make sure the clamp fits over it).
It depends on the turbo trainer, cheap fan based ones are noisy, fluid based ones are not so noisy.
Rob3rt
Man or Moose!
Manchester
To hang his underpants on. Why else would you want one?
To hold the washing machine door closed.
screenman
because i would like to get fit but sometimes cant get out on the bike due to weather or medical condition.
i don't really have a budget.
would like one that is quiet, easy and quick to setup, because if it to fiddlely i wont use it.
We have a couple of Cateye CS1000, not too noisy and have plenty of variation and information.
biggs682
Northamptonshire
fwiw i bought a pre owned one as not sure how much use it would get , but its getting used at mo and at the moment weather is ok so once it gets cold and icy should get more use
jowwy
Can't spell, Can't Punctuate....Sue Me
Ive just bought an elite realtour turbo which is pretty damn good and i hear the bkool ones are good too.
sittingbull
South Liverpool
I've had an Elite magnetic trainer for 7 years now. I leave a road bike permanently on it so it's ready to use. To be fair it doesn't get used often but it does get used. I like doing intervals on it and the longest steady "ride" I've done is 2 hours - when the weather has been bad.
I'm about to use it again soon and was checking it over last night. I've never used the cable operated lever to adjust the resistance as it wouldn't fit to the bars - I use the bike's gears instead. It turns out it's been on the hardest level (presumably level 5) all this time :blush:
No wonder it was difficult to start off smoothly :whistle:
