Probably a stupid question but here goes - should you change your tyre pressure when using a turbo trainer, for some reason I think I should let some air out?
I have mine close to the maximum pressure, just because it is easier to pedal. That's just me though, as even well inflated the thing is still hard work when the resistance is turned up.
When I was reading the Tacx guide which came with mine, it said inflate to at least 8 bar (I believe thats circa 120 psi). sure enough I've found any less and the tyre slips more.
