As long as you're only using it in erg mode it'll be fine. Tweak the adjuster so that it lines up nicely with a sprocket of your choice and don't touch those shifters
(In reality, you'll probably have a ratio either side of your chosen one before the chain gets jumpy, which might be handy if you switch from seated to standing, or get bogged down briefly by a jump in resistance)
I've used a 10speed bike on an 11spd DD cassette before without much issue just switching digitally in the pc or in ERG. Its some times a pain finding a gear to start but once you do as long as you don't manually shift it works fine
