Tubeless Tyre Advice
Soltydog
near Hornsea
I'm a touch heavier at 95kg & running 28s, on the road, at 75 psi, feels 'different' at first, but you'll soon get used to it, reckon 70-75psi would be ideal, unless you're more off road, then maybe lower still :okay:
Ajax Bay
East Devon
This is the venerable but high rep BQ article drawing on the late Frank Berto's expertise, which many reference. Need to use actual tyre width rather than spec (OP's = 30mm).
Really good article by Frank here: https://www.velonerd.cc/wp-content/2020/10/Frank_Berto-All_About_Tire_Inflation.pdf
For a 100kg load bear in mind the load will be split unequally front/rear: rule of thumb 10psi different.
  • TyreInflationPressures.pdf
  • Like
Reactions: C R
T4tomo
This chart is not for tubeless though is it?
Tubeless will allow you to drop another 10psi or so (as no risk of pinch punctures), which will increase comfort but also start to increase rolling resistance and also increase off-road grip / traction for gravel tyres etc . If OP is "mainly on road" then no need to go too low with pressures as off-road traction isn't a concern, it becomes a personal experiment / trade off between comfort and speed/ rolling resistance without the 'higher minimum psi constraint' that tubes / pinch puncture risk impose.
Maherees
Maherees
Northampton
I'm not used to tubeless but know I primarily used them on MTB's which allowed lower pressures but as a 'tubed' tyre on a road bike I'd normally have up 100psi, then I thought you'd get away with maybe 10-20% less.
Milzy
20% less for me.
I know someone who had 120 psi in their tubeless set up & got a gash & all the sealant sprayed all over the place. Nobody needs high pressure in TL.
