jayonabike
Powered by caffeine & whisky
- Hertfordshire
My new bike is coming with 2 way fit wheels and my LBS is advocating the use of tubeless tyres. He swears by them, uses them on his own bikes, says the ride is more comfortable and once I've tried them I won't want to go back to clinchers. He says the puncture resistance is far greater than clinchers.
He also said that there is a latex glue that's inside the tyre so if i do get a small puncture from a thorn etc it seals the hole, but if the hole is to big then you can use an inner tube, and the tyre fits to the wheel rim in the same way as a clincher does and doesn't need glueing to the rim like a tubular tyre.
If this did happen at the side of the road and I did need to fit an inner tube, would it be a pain in the arse to fit and messy with the latex getting all over my hands, kit and ending up with me swearing at the bike.
I'm not to sure what to do, part of me is thinking "stick with what you know" and get GP 4000 s' and the other part of me is thinking "try something new, you might like it"
Cost wise there's not a lot in it, the cost of 2 tubeless is about the same as 2 contis and 2 inner tubes.
A compromise I've come up with is put clinchers on for now and then next summer try tubeless. Or is this a waste of time and money.
