for the cost of some patches (£1) what's the point?I am sure others have tried this .... to fix a puncture a patch is stuck using rubber solution onto a prepared inner tube, you'd have thought you could make your own patch from an old inner tube and stick it on, but it doesn't work.![]()
suspect sniffing them now is not where near as effective as it was then!We always used old tubes to cut out patches years ago (many years ago!). I suspect the modern glues are different to the adhesives we used to use.
to save £ 1 ... I have loads of damaged inner tubes for which I have no real purpose, other than making into elstic bands...
