Tryres and Rims - how fat a tyre can I use?
KneesUp
My trusty steed has super skinny tyres on from back in the day when my bones didn't ache and I lived somewhere where the council made at least a token effort to keep the roads something approaching smooth.
Anyway, I'm at work and the bike is at home, and I can't remember what it has on, but I think they are 700 x 23, and the front rim is narrower than the rear.
Right - to the question. Riding it around this town on the tyres it has is like sitting on a pneumatic drill, so how do know what the maximum width of tyre I can fit is? (Assuming there is clearance in the frame)
Thanks.
JoeyB
Go on, tilt your head!
Thanks.
I might be mistaken but I think you just answered your own question....see the bit in bold
Banjo
Fuelled with Jelly Babies
South Wales
Obviously as joey B says the first thing you need is clearance but there are limits how big /small you can go on a rim.
The late great Sheldon Brown has a tyre size chart on his site which tells you what tyres go on what rims.
http://sheldonbrown.com/tire-sizing.html
Scroll down to a red and green graph which shows what tyre will go on a rim by measuring the width inside the rim
MikeW-71
Carlisle
Well.. to a point.
First, what pressures are you running the 23's at? Second, 25mm would go straight on and would be more comfortable as they need less pressure. Beyond 28mm you might need a wider rim. I await someone with much better knowledge to tell me I'm wrong on that one though.
