gazza81
- Edenbridge
I'm having trouble adjusting my rear gears, I've set the limit screws for the smallest cog and the biggest cog.
What seems to happen is with the chain in the smallest cog I change up one Gear to the next biggest cog if it doesn't change i tighen the cable via the cable retention screw.
Once it gets about 3 or 4 up the cassette I have to adjust the retention screw a little more but once I get to the last gear, the biggest cog it won't change into it?
Basically I've lost a gear either the highest gear or the lowest Gear I can't get them to change into all 10 gears.
I hope that make some sort of sense!
