EasyPeez
- Cottingham, East Yorkshire
It's my first attempt and I suspect I'm doing this all wrong...been trying and failing to get these off using the 6mm hex key on my multitool. It's not having it at all so I was thinking I'd get a longer hex for more leverage but am I even doing it right? Should I be trying to use a spanner on the outside of the pedal in conjunction with/instead of the hex on the inside of the crank?
Also, when it comes to taking the crankset off will I just need to slide an 8mm hex in here and unfasten? Or is there more to it than that? I've tried looking it up in my Haynes book but there are various connotations for different types of crankset and I'm not sure which relates to mine. It's an FSA crankset.
Thanks in advance for any help.
Andy
Andy
