Triple dropping straight to small ring?
Tommy2
Harrogate
Shimano sora 9spd triple, goes up on the front 3 ring fine but when dropping down from the big ring it goes straight to.the small ring as if there is only 1 click,.like a double?
Any thoughts?
I've tried adjusting the lower and upper limits and the derailleur inertia plate is only 1mm away from the chain when on the small ring.
alecstilleyedye
nothing in moderation
i've got the same problem. suspected it was to do with worn chainrings, but has persisted even since those were replaced. hoping it's not the shifter (tiagra 9-speed)…
Tommy2
Tommy2
Harrogate
It seems to have done it since they were new and they've not got loads of miles on them now, thinking it may be the shifter as when I flip the small lever to drop down and keep it held it goes down to the middle ring but when I let go of the lever just a little it drops the derailuer and extra click.
Something must be snapped of worn inside.
Tommy2
Tommy2
Harrogate
@raleighnut I just saw your message after I'd posted again, I've tried setting the lower stop then taking the slack out of the cable when it's on the small ring, is that right?
Or should I lower the low stop and tension the cable to adjust the derailuer in to rest position on the small ring?
Ian H
Ancient randonneur
As Raleighnut says, it's not the limit adjusters, it's the cable tension. Tighten it until the chain drops correctly on to the middle ring, then check everything else.
raleighnut
No you should adjust the tension so that when the middle ring is selected the front derailleur is centred on the middle ring, you should then be able to select gears 2-8 at the rear (on a 9 speed) with no chain rub at the front.
U
User6179
It is a lot easier to set up a triple set up correctly with an inline adjuster in place
lpretro1
Unless u already have down tube adjusters in place of course
I had a bugger of a job getting my Sora 9 speed triple to behave itself for the first month or so that I had it. It just seems to be very critical to periodically set the front to the smallest ring, and the rear to the smallest sprocket, then release the pinch bolt on the front mech cable, pull the cable tight, then retighten the pinch bolt, until the cable settles in, regarding initial stretching due to shifting when the cable is new. It's been the same story when I've replaced the cables as well.
Ajax Bay
East Devon
As has been discussed before, stainless steel cables do not stretch anymore than normal when new ie they stretch the same amount every time (the same amount of) tension is applied, throughout their life, from brand new to 'ready for replacement'.
mythste
Manchester
What has been discussed is that stainless steel cables do not stretch at all. The cable outers, however, may groove.
The linearity of that appears to be up for debate.
Plumster
Kings Lynn
Any thoughts?
I came across similar problem yesterday when setting up the gears on a mountain bike, instead of taking up the cable slack whilst on the smallest ring, I had to slacken the cable so that it would select the middle ring, if the limit screws are set correctly it will still drop ok to the smallest ring when required
raleighnut
It is quite usual on some set ups to have slack in the cable when in the small ring on a triple, as long as the 'low' stop is set correctly it isn't a problem.
