400bhp
Ahoy
I've done a bit of searching around but want to make sure my understanding is correct.
I have a Tiagra triple on my winter bike. It's getting worn so am thinking the best solution is to swap the compact Tiagra chainset from my other bike (fairly new chainset) onto my winter bike. I can then upgrade to a better chainset on my nicer bike.
On the winter bike I then simply need to adjust the limit screw such that it cannot use the 3rd shift function. It is better to use the limit screw on the inner chain line as that way you can still use the trim function on the triple shifter.
I shouldn't need to re-position the front derailleur as the large chainrings are the same size.
Does this sound right?
Thanks
Thanks
