A while back, a manny who ran a bike shop claimed that if you wanted extra gears with a rear hub, all you had to do was retain the double / triple chainring and the rear derailleur mech. His idea was that the rear mech would take up any chain slack during front changing and also act as the necessary tensioner required with a hub if your bike has vertical dropouts. He insisted it would work, but I'm not convinced and anyway, if it does, why has no-one else thought of it - ?
Advantage being that as the bike in question is my all weather commuter, then most of the gears are safely tucked away from dirt, wet, winter salt etc.. Should be interesting to see if I get any odd comments on the setup - !
