mcshroom
Bionic Subsonic
- Egremont, Cumbria
I've not met this one before, and I would appreciate any advice people have.
I've just been out on my mountain bike (an 8yo Voodoo Bantu) and the left hand trigger shifter was acting strangely. Switching between the inner and middle ring it worked fine, every time, but when I tried to move into the big ring it felt like sometimes there wasn't any resistance at all and it wouldn't shift - though I could do it by reaching under the bars and pushing it much further back than normal. Later on it worked a bit better, but it felt like I needed to pump up the lever a couple times before it would shift up. It's obviously not the case, but to give an idea of how it felt, it was a little like having to pump up pressure in a pneumatic system.
It always shifted eventually, and the shifting of the other two rings suggests that the cable tension is ok. I haven't had a look inside yet. I believe these are Acera shifter pods, but I usually ride on the roads so don't have much experience with flat bar stuff.
