wealthysoup
- Belfast
Hi Everyone,
I got a triban 3 from decathlon last month and when i use the biggest crank at the front (highest geared) the chain rubs against the front derailleur when im in the highest 3 or 4 gears. I took it back since then and somebody else set the gearing up but im still having the same problem.
Is this a typical problem with a triple or does it change over time as the bike is ridden? Do I need to take it back again to try to get it sorted?
Thanks,
Ryan
Thanks,
Ryan
. My Defy is a triple but I've never had any trouble that way. There's a thing I can do called 'Trimming' when the chain is rubbing. Can you do that on the Triban? Not exactly sure what's actually going on but perhaps a more savvy CCer will explain what it is.
