Trek Mountain Track 830 Rebuild - Tires
PensiveCrow
Hello all,
I'm new here so be nice. Recently I stumbled on this bike in someone's garbage. Frame is in excellent condition. Deralleurs are both in good condition. Chain rings may need straightening out in certain places but might replace the rear. Rims are straight but will need new tubes and tires. Trying not spend a fortune as its just a project for someone in my house to enjoy riding. Or maybe to resell on ebay. Or here!
So far I have:
- Brushed rust off various screw heads and the handlebars
- Repainted the handlebars, crank arm and spider
- Replaced gear shifters / brake levers with Shimano EF500's and cables
- Waiting to replace cable housing
- Ordering new seat post, clamp and saddle
Sorry for the saga but figured some context and color would help. So here's my question; what tire size(s) would fit this bike best? The factory rims are Weinmann 519, 32-hole. The outer rim edge to edge measures 1 inch. And they are 26inch.
I know this sounds like a dumb question but 26x2.10 seem to be the only option but wasn't sure if there are other options available that would also fit and be more readily available on the market.
Thanks for any feedback or advise in advance!
-Colin
raleighnut
Depends what you want to use it for, off road you'll probably need tyres that wide but road and light trails you can get away with thinner tyres 1.75 or even 1.5 wide.
P
PensiveCrow
After much digging on the interwebs I was able to find a PDF of the actual owners manual for Trek bikes in 1994. Turns out its original tire was a 26x1.75. So going to try that size and see what I can find. Finding a 26.6mm/300mm seat post was a different story! Very hard to find. Finally found a used one on ebay for $25. Not a common size at all. But shuold have it a couple days. Next a saddle and I should have everything I need to finish it up!
P
PensiveCrow
Another potentially dumb question; just received the tubes and they are 26x1.4/1.75 42mm Presta . What tube sizes would best fit a 26x1.85" tire with a wheel that is 1" wide? This compatibility is more complicated than I remember! Thank you in advance and cheers!
figbat
Slippery scientist
I have a 1997 Trek 830 Mountain Track that I rebuilt as a gravel bike a while back. In the planning phase I did a LOT of research and found a lot of information about this bike. I'll include it below for posterity, even though you have probably sorted your original query.
I can't remember where I found this, but I copy/pasted it from somewhere credible:
1997 Trek 830
Bicycle Type Mountain bike, non-suspension
MSRP (new) $389.99
Weight 29.0
Sizes 13", 16.5", 18", 19.5", 21", 22.5"
Colors Dark blue, yellow
Item ID 62492
Frame & Fork
Frame Construction TIG-welded
Frame Tubing Material True Temper chromoly, double-butted
Fork Brand & Model Trek
Fork Material Chromoly, unicrown crown
Rear Shock Not applicable
Rear dropout 135 mm
Components
Component Group Shimano Alivio/AceraX
Brakeset Shimano AceraX M-System brakes, Dia-Compe SS-8 levers
Shift Levers Grip Shift SRT-400i
Front Derailleur Shimano AceraX, top-pull/clamp-on 28.6 mm
Rear Derailleur Shimano Alivio
Crankset Shimano AceraX, 24/34/42 teeth
Pedals Wellgo LU-945
Bottom Bracket Shimano BB-LP26, 110 mm spindle square taper
BB Shell Width 73mm English
Rear Cogs 7-speed, 11 - 28 teeth
Chain Shimano CN-HG50, 1/2 x 3/32"
Seatpost Aluminium micro-adjust, 26.6 mm diameter
Saddle Trek
Handlebar Chromoly
Handlebar Extensions Not included
Handlebar Stem Chromoly
Headset 1" Victor VP-H913W sealed
Wheels
Hubs Front: aluminium quick release (Joy Tech?), Rear: Shimano AceraX
Rims Weinmann 519, 32-hole, 26 x 1.5 / 559
Tires 26 x 2.10" Trek Kahuna
Spoke Brand Marwi stainless steel, 2.0mm straight gauge
Spoke Nipples Brass nipples
