Is there such a thing and, if so, where could I get one? Humour me :smile: TIA
migrantwing Veteran 10 May 2014 #1 Is there such a thing and, if so, where could I get one? Humour me TIA
TissoT Guru Location The Home of British cycling 10 May 2014 #2 For what reason would you want a transparent one !
RecordAceFromNew Swinging Member Location West London 10 May 2014 #4 You can get a transparent front mech. It is called Nx1.
andrew_s Legendary Member Location Gloucester 10 May 2014 #5 If you use a compact chainset, you could think about using an MTB E-type front mech, with a jtek shiftmate to fix the cable pull difference.
RecordAceFromNew Swinging Member Location West London 10 May 2014 #6 andrew_s said: If you use a compact chainset, you could think about using an MTB E-type front mech, with a jtek shiftmate to fix the cable pull difference. Click to expand... I think E type mechs typically will clash with any ring over 44T.
