levad
OK, bear with me as this is the most technical diy on the bike for me to date.
My gears won't change properly, I tried the cable tension and indexing business and it got a bit better but I cannot get into 50/12 and am finding that I am running out of gears.
I have a Tiagra transmission system (although the derailer says 105). The chainrings are 34-F and 50-F and the cassette on the back says HG 50-9 and the smallest gear is 12T. I looked on master Sheldons site and used the ruler method to check chain wear, the pivot for the 12th link is about 1/8th of an inch out, Sheldon says that the chain is worn and that I may need to change the gears as well.
I have two main questions and one open ended question:
1) What options do I have for the chain, do I need the Tiagra HG-53 chain or is there something more durable or better quality.
2) Can I go to a 52 or 53 chainring? I have just read another post about this but thought I would as anway!
3) How difficult is it to upgrade to 10 speed (e.g. full 105 but keep the Tiagra levers)?
Thanks all-knowing folk.
