Globalti
Took the old Royce square taper Ti BB out of my Global MTB last night and was shocked at the mess I found. Muddy water gets down the seat tube because the post has two flats on it and despite the BB shell having a big drain hole the whole BB was filthy and the ali sleeve oxidised, as well as the sealed bearings being completely knackered.
But worse was the sheer hassle of having to pull off the cranks then unscrew the lockrings - after working out which way to unscrew them - then get the cups out and dismantle everything and clean it up. By contrast the Hollowtech crankset I fitted recently to my old Harry Hall was staggeringly easy to fit and took only a few minutes. In use I could tell that it was noticeably stiffer than the old traditional crankset it replaced. So I have just called Craig at the very excellent Ride-On in Rawtenstall who sells Global bikes and he recommended a Shimano SLX crankset with BB that he says he will fit for £100. Sounds good enough to me!
...anybody want an old Royce Ti BB (with new bearings fitted) and Middleburn MTB triple crankset with good rings?
