RSV_Ecosse
- Bonnybridge, Scotland
Hi.
I bought a track pump yesterday from Tesco, the one for under a tenner with the pressure gauge built in.
Couple of questions, as I'm a newbie and I haven't used a track pump before.
1. The tyres on my FP1 are supposed to have @120psi in them, but when I try and inflate them to that pressure, I get to about 90psi and it becomes pretty impossible to pump anymore air into them?. If I force my entire bodyweight down on the handle, I can get a couple more psi in, but am I doing something wrong?.
2. The bit that fits over the valve on the rim, it seems like I have to push it on overly far down onto the valve for it to get any sort of seal and allow air to be pumped in, is that normal?.
I'm thinking perhaps the two issues are maybe connected?.
Thanks.
Thanks.
		 the pump head is pushed as far on to the valve as possible to make contact. Otherwise it looks like it's pumping air in (ie the gauge goes up) but nothing actually is. This would give the same problem you are experiencing, and no air is making its way past the valve into the tyre. Just a thought.
		 I like the attention to detail!
