towbar bike carrier for 4 bikes
Buck
Yorkshire
I have a Thule one.
It's the three that you add a fourth carrier to and comfortably holds two adult and two kids bikes easily.
Not the cheapest unfortunately but if you can bag one on eBay you might get a bargain?!
Broadside
Fleet, Hants
jamin100
Birmingham
Take a look at BakRak's
More versatile than a bike only carrier as you can carry all sorts with them.
It's basically a metal plate that you can attach standard bike racks too
I'll dig a photo out if I can
Ok here's one,
Now I've got big Thule bike racks so with the standard BakRak could probably only fit 3, but they sell an extension which they say will take up to 5 bikes
But the good thing is you can use it to transport all sorts of things
https://www.google.co.uk/search?q=b...rhi5DMAhWK1hQKHRH-BVUQ7AkIgAE&biw=375&bih=559
Not sure if that link works as I'm on my phone but it's a link to a google image search for BakRak
KneesUp
I have a maxxrax carrier because I was given it. I've not actually used it yet but it seems well made. The bakrak is clever though; definitely worth check it out.
Oldfentiger
Pendle, Lancs
Ok here's one,
https://www.google.co.uk/search?q=bakrak&client=safari&hl=en-gb&prmd=simvn&tbm=isch&tbo=u&source=univ&fir=-8zYK1lpiw3wgM%3A%2Cmfd5hdCcCJ85cM%2C_%3Bd6ruUFzp5q4ivM%3A%2CbK80JyMCQrA4OM%2C_%3BLj2uNArgi8QALM%3A%2CMgxc9K8u3uMeNM%2C_%3B2B5sTeHzLod6JM%3A%2C2renHUgVp6CTHM%2C_%3B--Zfc4-z_xnVPM%3A%2CKKlJykKZb_lNAM%2C_%3BYpTCoMqExfSuRM%3A%2CRdSHkbJSVKslvM%2C_%3BcupiUCf7FJ8i3M%3A%2CMgxc9K8u3uMeNM%2C_%3BLie5h5iOzKvChM%3A%2CZs8R10eAD0g-0M%2C_%3BHKmGvt7A642uWM%3A%2CMW9Bd3FQF5IX2M%2C_%3BlSNd9h0vrit60M%3A%2CQJ054_VxboHjjM%2C_&usg=__tfAKifjL8L5iSIOSEDnQ1Wmo1uc=&sa=X&ved=0ahUKEwiKsbrhi5DMAhWK1hQKHRH-BVUQ7AkIgAE&biw=375&bih=559
Looks like a good idea, and a useful bit of kit.
Word of caution though........
Lots of cars have a towball weight limit of between 75 - 100Kg.
That limit applies at the towball, which is a couple of inches from the bumper. Any weight which is applied further from the mounting (i.e further away from the bumper) will have a larger effect.
I guess up to 4 bikes would be OK, but a heavy box for example could could potentially damage the towbar and/or car chassis.
jamin100
Birmingham
Yes defiantly check the weight of what you intend to carry. The bakrak is suitable up to 100KG if i remember correctly. but you would obviously have to include the weight of the bakrak itself when calculating the total weight
marknotgeorge
Hol den Vorschlaghammer!
Derby.
I have a Nimbus Saffier 4, which is okay for the money (£177 from PF Jones, including a free number plate). It tips to allow access to the boot, and folds down reasonably flat. However, the towbar attachment is by a clamp fixed by a big bolt. This is perfectly secure, but needs a fair bit of torque - I use a ratchet wrench initially, then finish off with the breaker bar I keep in the boot in case of a puncture. And if any water gets in the clamp, surface corrosion on the bolt makes it even harder to undo, so use a spot of water repellent grease.
The thing I would be concerned about is the weight. My rack has a limit of 60 kg, so 15kg per bike. But the rack itself weighs 21kg, so a car with a max noseweight of 75 kg only has a maximum capacity of 54kg.
