stumpy66
- Lanarkshire
Anyone know of a good but cheapish torque wrench, i have adjusted my seatpost but not sure if tight enough and dont want to overtighten
Can't you just do it by feel?
If it moves, it's too loose. Just keep tightening in incremental parts.
I would recommend the STW1012 from PVR - 3/8 drive. 2-24Nm. That range will cover most bicycle related jobs. I also bought an AK623, 3/8, 27.1-108.5 Nm, but that has had very little use. PVR also had a good range of hex sockets and converters. The whole lot - 2 wrenches, socket set and converter, cost me around £60 at the time, but you only really need the lower range wrench for most jobs.I have a Sealy Tools STW101 wrench. 5 to 25 Nm.
http://www.pvrdirect.co.uk/productinfo.aspx?catref=STW101
I also bought a cheap set of 1/4" socket hex keys for about £10 on fleabay as well as a 1/4" to 3/8" socket converter.
They seem to work pretty well. The wrench even comes with a three point calibration certificate BTW
Im just dont want to overtighten the seat bolt etc on my carbon frame n seatpost, its already slipped by nnot having it tight enough. Are they easy to set tomthe correct torqueCan't you just do it by feel?
