Torque Wrench
Glasgow44
Hi there
I've recently puchased a Torque Wrench (its called a Giant Shed Torque Wrench!). Anyway, on the instructions it says "remember to adjust the torque setting to the lowest value before storing in the case"
Does this mean put it back to zero because when you turn the dial it goes past zero and stops at between 0.1 and 0.2 (its almost like zero is zero but the between point of 0.1 and 0.2 is minus 0.1 and 0.2 as it is past the zero point - if that makes sense!)
I want to store the wrench properly
Gunk
Oxford
They just mean to wind it out and release the tension in the spring when storing it
Cerdic
Just wind it back to zero. Some reckon you shouldn’t go ‘lower’ than zero but I don’t know if it makes any difference…
  • Like
Reactions: C R
andrew_s
Gloucester
It's best not to go past the bottom of the scale. Sometimes winding out past zero can result in a screw unscrewing off its thread, and being very difficult to get back on against the pressure of a spring (SPD pedal tension adjustment comes to mind)
