I have a new Topeak track pump which when I push down on, the gauge shows 120psi (for example), but as soon as I stop pumping it slowly drops down and sits at about 100 psi about 2 seconds later.
Which is the accurate reading - I don't want to over-inflate my tyres, but at the same time don't want to be under-inflating by 20 psi each time.
Is this the same for other track-pumps - the Topeak was one of the more expensive!!!!
So far I've had a couple of nightmares - I changed my tyres (for Marathaon+'s) and after inflating the tubes went out for a test spin - 20meteres into it a huge explosion as the back innertube exploded - probably a pinch. Then I inflated a tube out of the tyre and after about four pumps it exploded - probably me putting too much air in. However, both incidents have made me wary of the pump and thinking about its accuracy!
Thanks
Kevin
Thanks
Kevin
