Tooltips for Posting form?
ColinJ
Puzzle game procrastinator!
Hi Shaun.
Is there any easy way that you could add 'Tooltips' for the icons on the Post New Thread and Reply to Thread forms? Some people are finding it difficult to work out what some of them do.
Actually, there are one or two I don't know the uses for as well!
Do what I did just click on them and see what happens
*Note to self do it again to remind your self what they do*
Shaun
Founder
Doesn't your browser show tooltips when you hover your mouse over the icons?
What browser are you using?
Cheers,
Shaun ;)
ColinJ
ColinJ
Cheers,
Shaun :sad:
It normally does, but not on those forms. Opera, BTW.
I just tried it in Firefox and still no tooltips. There might be some option that I've got turned off there, but I couldn't find it.
The tooltips worked in Internet Explorer. I could also see a couple of extra icons in the top RH corner which don't appear in Opera. In Opera, I just see some vertical arrows which change the size of the edit window.
grhm
I get tooltips here in IE6 - looks like the icons have an "alt" attribute which IE (at least) uses as a tooltip.
The HTML spec also includes a "title" attribute that is meant to be used to provide tooltip text - and this is not present on CC. Opera is usually more strict in its interpretation of the HTML spec - "alt" is meant to be displayed if/when the image is not shown (text browser or images turned off) so Opera is probably not showing a tooltip as there is no title and alt is not *officially* meant to be used as such.
Not sure if this is something that admin can modify easily but thought I'd add my two cents...
ColinJ
ColinJ
Ah, well spotted sir!
I like Opera and would prefer to carry on using it but it pees me off that it doesn't work properly on certain sites because they don't follow the rules. That sounds like a typical example. I'm not getting at Shaun, it's probably the original forum software to blame.
Websites should work properly in all browsers, but MS made such a crappy job of IE that everybody had to do silly things to get their sites to work properly for that.
It really pees me off when people have actually put browser detection on their sites and refuse to work with Opera, declaring it to be an 'unsupported browser'. I will then make them 'unsupported websites' unless I absolutely have to use them. They know there is a problem, but can't be arsed to fix it. If Opera wasn't working because of its own bugs, fair enough, but to penalise it for sticking to the rules - aaaaaaargh! :thumbsdown:
Shaun
Founder
Colin,
Can you just double-check that your browser is set to show tooltips?
Opera Browser -> Tools -> Preferences -> Advanced -> Browsing -> {Check} Show Tooltips
Cheers,
Shaun :thumbsdown:
ColinJ
ColinJ
Admin said:
Colin,
Cheers,
Shaun :biggrin:
It is because I get tooltips elsewhere on the forum (and on other sites). (Double-checks anyway...) Yep.
