To grease or not to grease stem?
oiljam
Active...ish Member
West Yorkshire
I'm replacing the standard stem on my wifes Triban 3 for a (shorter) deda zero 1. Do I grease inside the stem where it clamps on the steerer and handlebars. I know I need to do the bolts. Won't greasing inside the stem cause it to slip?
I've done searches and read some answers but I'm still confused.
amaferanga
Bolton
No, don't grease the stem/bars interface.
Perhaps you're getting confused by carbon paste which is used with carbon parts (but it's not grease anyway - it's designed to increase friction to stop slipping).
Shut Up Legs
Down Under Member
Any reason not to grease the stem clamps? I did this last weekend, to try to remove some persistent creaking noises, and haven't had any issues with the handlebar moving.
crazyjoe101
London
I oiled (not geased) every metal-metal contact of my quill stem as to elimninate some creaking noises (and give it a good degrease in the process). It got rid of 80% of the noise (the rest was the headset) and the only problem has been the handlebar clamp working loose, that was the screws coming out though, which has happened twice before... I hope I don't live to regret it...
Biker Joe
I prefer not to use grease on the clamp unless it starts creaking. Then I put on a very thin smear of grease. That usually cures the creak with no slipping problems.
oiljam
oiljam
Active...ish Member
West Yorkshire
Herein starts the debate. I knew it weren't that simple.
I'm going to leave the grease initially then if it starts creaking then I'll apply a little.
As far as I can deduce there really isn't a definate answer to this question.
Thank you all though for taking time to reply your take on it. Hasn't Mickle covered it?
Cyclopathic
Leicester.
I grease my seat stems because I don't want them to get stuck in there but I've never had that problem with handlebar/stem interface so I would not just grease it as a matter of course. To my mind it is better that this part does not come loose or have any encouragement to do so.
