Titanium and carbon fibre - anything I should know?
winjim
Smash the cistern
In the near future I will be starting a new build using super-duper space age titanium and carbon fibre parts. I've never used these materials before, so is there anything I need to know? Do I need special pastes and a torque wrench? I've always just used a bit of grease and some common sense. :scratch:
ianrauk
Tattooed Beat Messiah
Rides Ti2
Just this
Spoked Wheels
Bournemouth
I have a Ti frame and I haven't had a problem with it but I got one with a life time warranty. I read a few cases where the welding is a problem for some Ti frame.
You will probably go with a CF fork and mine has cf steerer too. No special paste but I use a 50mm expander, a tenner from planet x.
I have a cf seat post so I got myself a torque wrench.... handy for lots of jobs. A good tip for CF is got finger tight if you don't have a torque wrench :smile:
winjim
winjim
Smash the cistern
It's a refurb frame, so they'll have checked the welding. Ti frame and stem, CF fork (including steerer), bars and seatpost. Comes with headset fitted so hopefully they'll include the expander plug.
When its built you'll be needing a lot of Kleenex.
:stop:
ianrauk
Rides Ti2
You will be fine with all those components. CF will certainly not stick to Ti.
I have a Ti seatpost and have had no trouble it sticking in a Ti frame. I think the problems start when you have two different metals together ie an Alu seatpost into a Ti or Steel frame etc
I have never felt the need to use a torque wrench on both my CF or Ti bikes, in fact any bike. As long as you don't go down the hamfisted route then you will be fine. You soon learn the tolerances of nuts and bolts.
mangid
Cambridge
Just assembled my new Ti bike, used Copaslip on all threads (bolts, bb) and on seat post, used carbon fibre paste on the carbon steerer and Ti-Stem.
Spoked Wheels
Bournemouth
:stop:
One tip that @ianrauk gave me so the credit is all his. .... and it is a good tip.
The BB came loose 2 or 3 times so on Ian's advice I put some FTPE tape on the BB and the problem went away. I've heard the same issue with other Ti frames.
winjim
winjim
Smash the cistern
A good portion of my working life is spent taking apart and reassembling lab equipment so I'm pretty handy at telling the difference between tight enough and too tight. :okay:
I'm using Campagnolo Ultra-Torque, which comes ready covered in threadlock type stuff. I hope that might be enough, but I'll bear it in mind.
