CharleyFarley
- Japan
I got my Electra cruiser out for a ride and quickly saw that the back tire was flat. These were new tires I installed 30 months ago. They are in very good condition, it seems. So I removed the tire and checked all around the inside of it with a flashlight and feeling it with my fingers. Examining the outside of the tire there was no evidence of any sharp object having penetrated it, so it seemed odd that the inner tube had a tiny hole in it.
Examining the inside of the tire, again, I saw that the casing is made up of nylon threads fairly close together, but there were patches where it wasn't attached to the rubber exterior. I'm figuring that somehow the tube was getting pinched between those nylon threads until the hole was formed.
I've put 3,800 miles on the tires and they're in good shape to look at. I don't know if the tire is defective or if normal wear can cause the casing to separate in patches from the rubber exterior. I've always kept the pressure to around 40 PSI. I've patched the tube for now, but I'm wondering if it's going to damage the tube again.
