Time Trial advice
roscco
Hi, recently completed my first 10 mile time trial. My time was okish, considering ive never done one before and still carying some puppy fat around the midrift. This was on my everyday road race bike. Id obviously like to improve my times, fitness will be the major thing im concentrating on! But without spending thousands on a specialist bike, are there any little things that might help (apart from losing weight).
ive been told ...
Tri/aerobars
Tighter fitting top
Any other sensible things i will need?
Any sensible answers appreciated :biggrin:
Thanks!
Sonofpear
South Shields
Have a look in the racing section. There is a post about starting time trials.
Will1985
South Norfolk
In order, beginning with the free things:
Clothes - wear the tightest fitting jersey you have, or even better a skintight base layer. Do not wear gloves. Some cheap lycra overshoes for £10 might come later.
Position - move the stem down as far as you can go, putting the spacers above it. You can also move the saddle forward (and maybe a tiny bit up) to help your more aggressive position. You should be able to have your hands on the hoods with your elbow angle between 90 and 110 degrees. MAKE SURE YOU NOTE YOUR ROAD DIMENSIONS BEFORE MOVING ANYTHING!
Tribars - a set of clip-on tribars can be bought new for less than £50, or used for as little as £10 on ebay. Set them up properly and this will suddenly knock a huge chunk out of your time.
Helmet - an aero helmet such as Bell Meteor or Giro Advantage for around £100 in place of your road helmet will smooth the air around your head and offer more time savings. The head is the inconvenient bit on top of an un-aerodynamic mass, so anything to make the head and body appear as one continuous object is good.
After this unfortunately it becomes expensive for relatively small improvements....
Tyres & Tubes - rolling resistance is your enemy. Some fast rolling tyres such as Continental Supersonics, Veloflex Record, or Vittoria Open Corsa Evo CX paired with latex inner tubes will help, but will also degrade faster than stock tyres.
Carbon wheels - take your pick. The front is more important than the rear as it is cutting through clean air. 50-60mm Deep sections make a noticeable difference to any bike but at a huge cost.
Skinsuit - short of getting a full-on TT bike, this exhausts the upgrade possibilities. Prices range from £50 up to around £200
I'm a regular tester knocking out mid 21s on sporting courses with a full TT setup, and short 23s using a standard road bike, skinsuit and road helmet - 90 seconds difference for proper TT position, trispoke + disc, aero helmet.
Nebulous
Aberdeen
Cracking post Will - although it wasn't me that asked thanks very much.
I did my first 10 mile TT last week on a stock road bike and am likely to do a 25 next week.
You have certainly given me food for thought about changes without going straight to discs and TT bike.
edindave
Auld Reeker
Thinking about getting into TTs myself... I just watched a TT DVD guide featuring Cancellara and the easy wins seem to be:
1) proper warm up pre TT: short TT - long warm up; long TT - short warm up
2) proper nutrition: before, during and after
Aero wheels only give a 2% improvement according to the video, whereas body position was a lot more (can't remember the number sorry - but they were on about wind tunnel training!)
WychwoodTrev
Have you thougt or heard about the benifits of Beetroot juice ? Seems it helps your muscles work using less oxygen and boosts stamina by 20%
