Good afternoon,
............. I'm going to take a stab here and say that the torque the Skarper can deliver via the special for purpose rotor is tiny compared to the effective torque of braking and the fact that the direction of torque differs will be irrelevant. But idk.
Why would one allow a rotor to be "even slightly loose"? ..........
Do you remember when disk brakes were introduced, they were nearly always on Quick Release wheels?
Then there started to be reports of Q/R skewers just undoing themselves, the forums, “letters page”, bike sites and manufacturers all said
Rider error.
Now Q/R has been replaced with through hubs, why, because it was worked out that there is "sweet spot" where the wheel feels tight enough to the user but is just loose enough that certain twisting motions that occur when a disk brake is applied slowly undoes the skewer.
So the people with a loose rotor could be the same people as those with loose Q/R skewers.
The way that I understand the Skarper motor is that most of the 4.5kg weight is either in the rotor or hung off the rotor rather than being rigidly mounted to the frame.
So when going round a corner and leaning the bike over, some of this weight will now be
pulling the rotor away from the hub which is a direction that is not seen with a standard disk brake.
Powered or unpowered applying the brake will try to move the rotor clockwise in relation to the wheel hub, by the spare space between the mounting bolts and the holes in the rotor and as it can't move much we have braking. (viewed from the non chainring side)
With an unpowered bike if the rotor does slip slightly on the first application of the brakes there is nothing to force it back to its starting position.
If you add this motor, accelerating will try and rotate the rotor anti clockwise back to its starting position, starting a cycle or rotate/unrotate.
These bolts are usually quite lightly done up, typical torque setting for these bolts is 2Nm-6Nm and with the motor weight trying to bend the rotor outwards the friction between the bolt head and the rotor surface has been greatly increased. Possibly making overcoming the clamping forces between, bolt head, rotor and hub more likely and undoing the rotor bolts
Of course this won’t happen and if it does we can all blame the rider for not checking his rotor bolts often enough.
Bye
Ian
