RD's are dumb and are controlled by the shifter, this is why when people refer to re-indexing the gears its wrong, anyway so almost any RD would work, just set it up as you would your current one, i.e. shifter in high gear, adjust the RD so its in line with your smallest cog (highest gear) with the high stop screw, attach cable finger tight, adjust cable slack with barrel adjuster holding the RD with your fingers you will feel as soon as the slack is taken up, this should then go through the gears as you change the shifter.
See no mention of indexing at all.
