grellboy
I've got a lot of lateral play in my rear wheel - probably caused by bumping up kerbs - and now want to tighten the cones to eliminate this. Only problem is I don't actually know what I'm doing! Using the picture below, I'm thinking that the part labelled 2 is what i need to tighten but not sure if this is correct and also whether it should be anti or clockwise. Also did read somewhere to beware tightening the cone against the bearings (part labelled 3?) in case of ruining them. In summary, which part do I put the spanner on and which way do I turn it?
NB - The photo I labelled as 1 2 and 3 won't load up so will now try one not labelled, but if we go from the top it's 1, 2, 3 - 1 being the chunky nut, 2 being the nut in the middle, 3 being the round cylinder which I imagine is the bearings.
just to be as clear as mud.
