robbarker said:
Lots of people, including a fair few bike shop mechanics, don't routinely use torque wrenches. The world of cycling is full of stripped alloy threads, loose headsets, clicky bottom brackets, groaning cranks and slipping seatposts. This is not a coincidence.
If you want to do the job properly, you need at least two torque wrenches - a little one for the smaller fastners and a meatier one for things like crank bolts.
I'd agree...and disagree :?:
If there is any uncertainty or lack of experience...get a torque wrench if you want to be sure.
But even that wont stop you stripping previously damaged threads.... if you put blind faith in a torque wrench and the threads are damaged...you may still strip the threads.
Experience MAY tell you not to go too tight (by hand )with damaged threads, but thats down to luck as well.
Its a matter of degree IMO.
If you own an expensive carbon jobby...i think even i'd get a torque wrench.
If its a hack or moderately cheap bike, i'd tighten by hand and feel.
Theres also the point if you use a torque wrench, you'll NEVER get to know how to tighten bolts by feel.
Its not rocket science...Cranks for instance (although the same applies to almost any application) . Tighten them by feel. Not too tight you have to strain. You just need to check and maybe check again in a few days or weeks to see if you did them tight enough.
But then
i know some engineers who tighten things up like their lives depend on it...and accordingly strip threads occasionally.
Theres no easy answer. (This is not aimed at anyone specifically, just an observation) Think about what you're doing. Think how tight that feels. Go back and check it after some use. Check it again if neccessary. In other words....learn. Most of us are quite capable. We just need to learn...it takes a little practice and time, thats all.
