harlechjoe
My home town of Harlech is destined for a Tiger crossing to help children cycle across a busy 'A' road to school. I know they were piloted in London. Do they work ?
Yet the crossing was welcomed in CardiffThe tiger crossing trial failed and it was Aylesbury not London. They are not normally allowed. Maybe you are getting a parallel zebra? See https://www.cyclechat.net/threads/tiger-crossing-uk-who-uses-one.282427/
You really should be thanking the English for boosting your tourism industry by coming over and building all those fantastic castles.Great photo & well done for cycling up to our castle
Ahh, well there you go, it is your castle.I am English
That's a parallel zebra crossing. Tiger crossings were yellow and black striped, hence the name.Yet the crossing was welcomed in Cardiff
"There is at least one in Cardiff Here. I've used it in the past, although usually coming out from the shared use path and turning onto the road, and my normal commute now is all along that road.
My experience is that motor traffic DOES generally give way to cyclists there, just as much as they do for pedestrians"
I often use that to pull on to the bridge and motorists always give way. The only trouble I have had there was with a bus which then tried to squeeze me right into the kerb when I was undertaking it in the cycle lane at the other end of the bridge after it had been stuck in a queue.Yet the crossing was welcomed in Cardiff
The parallel crossings are commonly known as Tiger crossings, although officially that name is not used, because it has been used to mean other things, such as your Aylesbury example.That's a parallel zebra crossing. Tiger crossings were yellow and black striped, hence the name.
The "cycle lane" over the bridge is ridiculously narrow.I often use that to pull on to the bridge and motorists always give way. The only trouble I have had there was with a bus which then tried to squeeze me right into the kerb when I was undertaking it in the cycle lane at the other end of the bridge after it had been stuck in a queue.
