Deleted member 26715
Some time ago I noticed that I had a noise on the crank, it was there when I first start to ride but would disappear after a few miles, it's now got to the point where it's there all the time. It's not loud but a slight tick/click can be heard somewhere between 6 & 7 then again somewhere between 12 & 1. I checked my knees & it isn't them, but it's definitely on the crank as it's consistent on each revolution. It's only very slight but it's now getting to that annoying state, it has SM-BB52 Mountain written on the non-drive side. I can't feel any movement when holding the pedals & trying to flex, it's only done around 1400 miles, is there any adjustment or does it need to be replaced?
It's not a system I'm familiar with, do you remove the non-drive crank with the allen keys, then does the drive side then pull through, then allowing you to unscrew the outers of the BB, is this a special tool?
