Thunder & Ligtning
cycle_bug
thought i had something more to say
Having been seriously considering commuting and building the 'its only a bit of rain' attitude rather well, it did strike me (no pun) that in the UK we do get a touch of some 'extreme' weather now and then.. thunder but more worryingly lightning.
- Is it dangerous?
- What to do if it happens during a ride?
- Any useful information about it?
I found out that its definitely not like being in a car - even with being on rubber tyres - as that phenomenon depends on the car body acting as some type of cage.. so I'm now literally worried if I cycle in this weather I'll be struck by lightning..
AndyRM
XOXO
North Shields
Unless you're the highest point, which I would say is pretty unlikely, you're not going to get hit.
As long as you don't go out with a bloody great pole attached to your bike, you'll be fine.
ianrauk
Tattooed Beat Messiah
Rides Ti2
I have commuted through a fair few thunder (and lightning) storms over the years. Rain so heavy and hard that it was impossible to see. If that's the case I usually stop and wait for it to pass as heavy cloudbursts like that don;t last long.
And sometimes, especially in warm weather, in a mad way it's quite fun.
Midlands
In the ordinarily course of thing being struck by lightning on a bicycle is pretty rare - but having sat and watched a fair few alpine thunderstorms where the lightning was striking less than a hundred metres from where I was cowering then it can be just a little intimidating and shouldn't be taken lightly
Deleted member 26715
Is there a greater chance of being struck than walking in in the same storm?
It's actually quite fun getting stuck in a huge downpour !
Midlands
If you think that you have never been in a proper downpour - hailstones big enough to dent cars and smash windscreens - solid extremely cold rain - and flash to bang time almost simultaneous
jonny jeez
Surely as you are insulated from earth by rubber tyres, you cannot be effected by lightning...strike or no strike?
Is there anyone here here who understands meteorology and physics who can comment?
Origamist
I can't say I've ever worried about lightning in UK, but when it gets really dark and the rain is teeming down visibility is a real problem as traffic rarely slows down much on 60mph NSL roads. In these conditions, I take shelter or pull over as the intensity doesn't usually last too long.
subaqua
What’s the point
Leytonstone
yes. we will use you as guinea pig and then you can tell us . ;)
how high a voltage and current rating do you think the tyre is rated to ?
car acts as a Faraday cage hence protected inside it . bike unlikely you wil get hit but if you do then you may look a little
Tim Hall
Crawley
Seeing as the lightning bolt has just passed through however many thousand(?) feet of air, do you think 28mm of rubber is going to make an awful lot of difference?
