Thule 970 xpress
jann71
West of Scotland
Anyone use a thule 970 xpress cycle carrier on a towbar?
Just bought one today but when i went to fit on the car it seems too tight!
Do i need to use a bit of effort or put alot of weight on it?
I thought towbars were a standard size.
Nebulous
Aberdeen
I've never used one - but towballs are a standard size (50mm if I remember correctly)
Did you install the towbar or was it there already? There is an issue with Al-Ko caravan stabilisers as they don't fit many towballs and you need to replace the ball with one with a longer neck.
What do the instructions say about fitting it to the ball?
I use a thule one which fastens onto a plate bolted on behind the towball. It carries 4 bikes, but needs a separate number plate board and lights.
It appears to bounce a lot if you watch it in the mirror, which is quite scary - but we drove to the South -West of France this summer and did over 3000 miles total with no problems.
jann71
jann71
West of Scotland
Towball was already fitted when I got the car so don't know what it towed.
Instructions advise to wipe with something can't remember what as I'm at work.
jann71
jann71
West of Scotland
Photo attached.
