Thru Axles?
grellboy
Afternoon. I am hoping to buy some wheels from ebay. On closer look, the advert describes them as "thru axle". The photographs supplied with the advert don't show any kind of skewers - in the same way you might see a QR skewer for example, so just seeking from advice before I ask the vendor and make myself look like an idiot,! 🤦‍♂️ What does this thru axle look like?
It's a separate axel that threads in and locks. Needs a specific frame/fork, so if you need QR, then you can't use these.
grellboy
grellboy
My bike uses QRs. I assumed these would be a straight forward swap (my knackered wheels are Cannondale Maddox 3.0, these were 2.0) but I guess it's a non starter then?
steveindenmark
The forks on your bike need to be designed to take through axles. They look like this. Nothing lije Qrs.
494858
494858
grellboy
grellboy
Ok, thank you everyone. Good ol' Cycle Chat, was definitely gonna buy them too. Back to the drawing board.
robgul
Just to add to the confusion - there are several types of "thru axle" - all of which have same type of fork requirement ... not the traditional open slot dropout but a "round hole in the fork end"
1 - simply screws in to a thread in one side of the fork with a modest amount of torque (with an Allen key)
2 - screws part way into the thread and then has an over-centre cam lever (like a tradiitonal QR skewer) to take up the tension
3 - an axle with and expanding centre at one end, similar in style to #2 but with out the threaded end (IIRC these are only found on a couple of brands - and are the work of Satan to adjust/use . . . IIRC some of the Voodoo MTBs use these.
Rob
boydj
Paisley
You'll also see the rear axel will be 142mm rather than 135mm. QR are 100 fromt, 135 rear. Stick with the same.
QR rear on a rim-brake bike is 130mm. 135 or 142 is for disc brake rear.
Pale Rider
Rob
Suntour Q Loc, which I have on the front of my bike.
Fiddly, over-complicated, and the stupid thing rusts in the fork if left for more than a month or two.
This is the party line:
View: https://www.youtube.com/watch?v=U8IqJD34Ky0
robgul
Yep - that's the one, and agree with your summary .... AND from experience having to replace one (about £40 for the part IIRC) for a customer they don't like kids doing wheelies and jumping off 12" high steps!
Rob
silva
Belgium
Related question, I've a bike with frames front wheel mounting holes in de middle of recesses sized the circumference of M12 (rough guess) large diameter washers (as used for fixing on materials than cannot withstand larger pressures alike plastic plates)
The wheel is fixed into place along screwed on nuts, so the recesses look like as there without reason / unused. Could it be that the frame was designed for QR but unused like that?
