Freddyflintstone
Hello
I bought a new Probike Discovery For £150 (retail £299) for going to work etc
Noticed the pannier rack was bent & twisted
Back wheel was buckled by 3mm - Their warranty on the Web states it can be 4mm thats normal
Gears did not work correctley - Their reply "If you know anything about cables - they stretch" ( 10mm and the nuts are loose ??)
Gear cable housing was cut at the top and cut/split in 3 places under the crank - No response from Seller
Nuts on axle and seat post chewed thru using wrong tools - again no resposnse
One wheel spoke is bent
The bike is now 3 weeks old and now the spokes have started to corroded (its kept in the house)
Their attitude is "you bought a bargain - get it repaired -you will be quids in" Their words
Their terms state "The bike is tuned -fit the pedals -position the handle bar and its ready to run"
Anybody else had problems buying from Sellers miles away via the net
Your comments would be most appreciated
