wintergreen
- Sunny Manchester
I have been looking around for an accessory bar for lights, gps, etc and have found theThorn Accessory Bar which would be perfect. http://www.sjscycles.co.uk/thorn-accessory-bar-mk1-t-shaped-105-mm-extension-222-mm-0-deg-prod11040/
The only problem is the ammount of spare space I have under my stem is pretty much the same as is needed for the accessory bar.
Would it be ok to fir the bar without any spacers between that and the headset or would it be better to find a 1mm spacer to fit above the headset?
