This pump look ok ?
Make sure you keep a glove on when you use it or you'll freeze your fingers off!
I've given up on c02 TBH and just carry a Road Morph these days.
cyberknight
cyberknight
I carry a road morph for commuting but i need two bottle s for non commute rides unless you can get an offest mount for it?
I currently have a race rocket but i managed to get 70 psi out of it .
ohnovino
Large Member
Liverpool
I've been looking at CO2, but instead I went for a Lezyne Pressure Drive. It arrived this morning, I've given it a quick test and I'm amazed with it. Gets 700x23s up to limp-home pressure with no effort at all. Put a little bit of force in (which is easy to do because the hose means you can get a good grip on the pump) and it gets over 100psi pretty quickly. Beyond that it's more of a struggle, but I reckon with enough force and patience I could get 120psi+.
Only £24.25 @ Merlin, and mine was delivered in 24 hours.
cyberknight
cyberknight
Cheers folk, i will have a think ^_^
I do have another pump i can use a topeak master blaster that gets tyres up to pressure but its fairly hefty so i either carry a bigger pump that can get up to pressure or the race rocket + C02.
