swee'pea99
I decided to finally take the plunge and try to sort out my old Shimano 600 rear mech. I'm trying to make the slight adjustments with the barrel-adjuster, but it's not going that brilliantly. I think it might be something to do with this part here:
If I'm reading it right, the right-hand one of the two milled sections - ie, this feller here:
should move independently of the other, allowing me to adjust the cable-tension by varying the gap (currently zero) between the two. Is that basically correct? Or is there another reason I just cannot get it to turn. Basically, is it just that it hasn't been adjusted in 20+ years so it's got a bit seized up, or am I trying to unscrew two parts that are actually part of the same thing, and don't turn independently at all?
