ozboz
- Richmond ,Surrey
I have not seen one like this , the little pulley wheel below the barrel adj,
Is it a common feature , the bike came from Denmark ,
Correct - https://bike.shimano.com/en-NZ/technologies/component/details/wheel-type-cable-guide.html and used on quite a few Tourney TZ rear mechs.Turns the cable 90 degrees without the attendant friction of the cable inside an outer (and increases the turn radius of the rest of the cable from the chainstay stop. [ETA: This reduces the pressure required with the right thumb on the shift lever; and image.]
Odd that Shimano use this on their very low end MTB range, yet SRAM use it on their top end Eagles
